very nice!
can't wait to see dyno results!!
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/toond.jpg"></a>
very nice man!!!
what PVC part do you refer to? and how does it feel??
pvc part is the white part in the whole car shot, hard to see. it feels nice, very smooth pull. i don't have my 2 bar map sensor in yet so no good tune yet. i won't be going to the dyno
i am tuning it my self with my wideband and emanage.
boost on a budget. i love it.
nice work and good luck with it in the future.
ill be the first to say that set up is fawkin getto
dude thats just nasty
ill give ya credit for doing it your self , but thats it
97cavie24ls(JDM cav sedan™) wanna race?? didn't think so
ill race you lol....from the looks of the wiring your car will probably catch on fire- blowing it up allowing me to win
haha, yeah i have to clean that up, oh i will own you the other matt.
hehe i thought my set up was ghetto!!! DOH! nah man its al good..can your hood even close with that charge pipe hanging over your core support?!?! hehe anyways you just need some minor tuneing up on your parts and youll be all set..at least your intercooled unlike my setup =(
eh, the lower stuff by the intercooler is pretty gross, but i've definitely seen MUCH worse setups than that at least years bash... I'm talking crush bent exhaust pipe for charge pipes with welds that had more carbon than metal.
Just a few things:
Clean up the wiring
Relocate the filter, if the heat back there is anything like it is on rich's car, you're really hurting yourself
Better intercooler, but you already knew that.
Are those charge pipe bead-rolled on the ends? If they aren't you might want to watch out for those blowing off if you decide to go higher boost.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
I agree on the filter setup..mine is in the exact same spot but i plan on turning my 90 the other way around and pointing the filter down instead of up in the engine compartment. Heat rise's and that should help out alot! Also I dont think ill ever go through a puddle high enough to sumerge it...it would have to be a small 4 ft stream to hydro it ..=)
oh yeah, deekster that is a good idea, i am going to do that.
1.8t- yeah, most of those pipes are bead rolled, i have been running around for two days at 5psi, nothing is blowing, but i am upping the boost to 8 psi here soon.
QBE- what kind of fuel management are you running?
coldfusion wrote:97cavie24ls(JDM cav sedan™) wanna race?? didn't think so.
LoL... You told him you want to race. I'm sure Eric can just put the turbo back on his car that is just layin' on the ground in the garage and beat you, but he does have a point that the piping on the intercooler is just simply getto. I think if you moved the battery it might of been a lot easier to run a cleaner pipe system. You might even be able to use the same bends you have in a different order to make it look a little cleaner. Just my .02, and don't ask me to race either please.
I love it... who gives a crap what it looks like. Once your hood closes....it dont matter anymore. What was your final price tag for everything?? Id rather say "i got 1200 bucks into the project...but it aint pretty" then say "i got 4k in the project, but it looks total BLING BLING "
Congrats on boosting it. That wideband looked cool...got a link to it? I say suck your air in somewhere else though.
ahahahahahahahahahaa
im so frekin scared
which car of mine you wanna race ?? i got 2 cavs , 1 scx , 1 68 elco , 1 29 tudor sedan
take your pic
you install looks like fawkin sheet , all the different pipe sizes , the duct tape engineering
go try and e-thug else where , if you cant take any critisim
punk ass bitch
i just dont need your useless @!#$. just cause i spent half the money you did on a turbo setup doesn't give you the right to say that my car looks like crap, i already know that.
not my fault you cant take constructive critism
and i did comend you on doing the job your self
so either learn to expect the truth , or dont post
im actually suprised more people didnt speak the truth
and i though some of my set up looked like crap , if you wanna look at it here is a link
http://www.cardomain.com/memberpage/478869/6
keep in mind the more rubber/silicone connectors , the more boost issues you will have because they have to expand and contract , also the same goes for the differences in piping size , you want to keep the size mostly the same
^^ You're right about different pipe sizes, but silicon connectors aren't going to have swelling issues under boost until you're way above what a stock internal eco can handle anyway. Most of my charge pipes are entirely rubber, I run 20 psi and don't have any abnormal fluctuations, and the guys running all-metal ones haven't seen any difference in power or boost level between the stock rubber and new metal replacements. Personally, the only stuff i pointed out is the stuff that is hurting efficiency and performance, which also happens to look the worst. Otherwise, showcar flash and bling bling have nothing to do with going fast, so who really cares? Its hardly something to work yourselves into a pissing contest over.
Eco
Turbo
Megasquirt
'Nuff said
JDM cav after seeing your setup, i now respect your comment. it does look like @!#$, i am getting a new front mount and will hopefully make the piping better.
sorry if it seamed to harsh
like i said , i comend you on doing the job , most wouldnt even try
just try to keep the amount of connectors down , and keep a uniform size for the piping
im sure the way it feels will be alot better
you know what i think it is great, yeah you need to work on the fit and finish alittle but hell i wish i had it, i would just fix it up here and there as your budget allows, i understand completely what your doing, i did the same thing only with an intake instead of a turbo...not coz i didnt have the money for an AEM or Wepon R... i just refuse to pay 200 for a piece of pipe and a filter, so i got an ebay special, just had to work on it to make it fit, painted it, and now it looks like an AEM but only cost me 30 bucks. it wont take much at all to make that thing look like you had it professionally installed. again great job and take the negitive coments with a grain of salt. keep it up bro.
