Is it worth it? - Boost Forum
Is it worth it?
Monday, April 25, 2005 8:21 PM
im looking at getting a turbo system for my 2.2L, but i want to know if it would be worth it power wise. im not looking for any astronomical figures, somewhere in the range of 220ish hp. im new at boost so i would appreciate any recommendations as to good kits and where i can get them. i've seen a few systems but im not sure if they are good or not. if i get the kit i plan to do internals and all that jazz, not just bolt up the turbo and go. if anyone could give me some advice or pointers i would greatly appreciate it. thanks
Re: Is it worth it?
Tuesday, April 26, 2005 12:09 PM
if you want 220 whp build your own kit.
Re: Is it worth it?
Tuesday, April 26, 2005 12:37 PM
Hell if you are putting internals and the proper fuel, I say go all out and run 20 psi since you'll have the bottom end and fuel management to do it.
Failure is not failure if you learn from it
Re: Is it worth it?
Tuesday, April 26, 2005 12:57 PM
02turbo wrote:Hell if you are putting internals and the proper fuel, I say go all out and run 20 psi since you'll have the bottom end and fuel management to do it.
i'd love to see the transmission and cv axles after running 20 psi
Re: Is it worth it?
Tuesday, April 26, 2005 1:34 PM
problem is i dont know how to build my own kit. im trying to get more info on the basics and figured a kit would be a good way to start out. thats why i'm on here, trying to get more info
