Well I finally got my new 2.4 installed. When I went to turn it over I had to crank it forever then finally she started. After a sec or two she idled perfect. I then went into the low setting on the afc and added fuel to see if it ran richer. Nope wideband says nothing perfect 14.7, so then i went into the thr point and put it to 0-low and 70-high the added fuel, nothing wtf I used the wiring diagram that shifted posted. Eveything else works the knock and throttle, rpm also works. Someone shed some light on this. Thanks
Do you have the pressure setting at 05 in and 05 out?When i had my settings at 04 in and 04 out,the s-afc wouldnt do anything.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
You posted a link (sorry) im at 05 in 05 out and have my lo setting to 25 and hi at 70 and nothing. Wtf @!#$ is bugging the hell out of me. My base fpr is at 35 and my cartech will only go to 50 at its lowest setting. Let me know any suggestions.
check your wiring diagrams again and use a soldering diagram and 0 % will work on a safc i use it on mine
"dude, thats a girls car"
PSHHHTTT NOT ANY MORE!!!!!!!
