Where did you 2k guys tap in for your tach signal? I tried tapping off the pink wire on the ICM and got absolutely nothing. I know it had a good connection, I tested it with a multimeter. I'm at a loss here, its the last step to getting my SAFC-2 wired in...
Insight?
I tapped mine into i think the black connector pin 10. Hope this helps.
I know you have to get the pin from the dealer thats what I did. Worked perfect just use something sharp to pop out the little rubber and slide the clip in. Simple and Easy.
Not a problem!!! Of course it works great. Now that wil be 29.95. I take small bills large ones it doesnt matter. J/P anyway what setup do you have (tell me everything) and what your afc settings are. Im trying to have the motor and fired up tomorrow. Good luck.
I've got a SAFC-2 question too although mine is concerning the knock sensor. What kind of numbers are you guys getting (N/A)? Mine always reads zero and I think maybe the wires are loose or I wired that one up wrong. Any help would be appreciated. Thanks.
i have ??? too about the knock sensor readings im starting a new thread so i dont get flamed for thread jacking lol
"dude, thats a girls car"
NOT ANY MORE!!! PSHHHTTT!!!!
......someone answered a question for shifted....... now ive seen everything....
I know im da man!!!! Sike far from it.
shifted...i thought i came across a post that had a diagram of the 99 PCM? you posted for someone who had a question on a SAFC-2 hook up. if you still have that link floating can you post it for me please.
