when i turbo my cav how much is a safe amount to run with stock internals
Shifted (KickAzz) wrote:Read the FAQ.
Be nice... I have heard you can run like 10 to 12 psi...
Run 10-12 psi with a T3/T04E and then run 10-12 psi with a T3. You can go run 10 psi with a T3 and be safe while running 10psi with a T3/T04E will send your rods throught the block.
And what you "heard" is not good. If you don't know how boost work, don't answer. It's not like N/A power. things are alot different.
And I'll quote Shifted:"You can blow your engine with 1psi". It all depend on the turbo and the power output. It's not the PSI that brake things but the power. Psi = measure of pressure, not power. Cfm is closer to power than Psi.
Gilles
2.3 Ho
^----------- I wouldnt listen to a word this guy says
for noobs, i recommend 6 psi professionally installed.
lmao, you wouldn't listen to what he said???
I hope you are being sarcastic cause that was total OWNAGE of YOURSELF!!!!
It is true 10 psi on different size Turbos put different stress on your motor and it is not PSI that breaks your motor it is the power that psi makes due to extra CFM's.
11 second daily driver!!!!
Race Related 727-561-9440
13's
----12's
----11's
----10's
would that be safe for the eco to?? 10 -12 psi stock internals ..
austins04cavie wrote:would that be safe for the eco to?? 10 -12 psi stock internals ..
If you didn't get the point of what most people were saying here, you need to be more specific, namely being what turbo, and what supporting mods (fuel and ignition) you are planning to do.
