When supercharging the 2.2 ecotec with gm flash I am to use a 2.5 map. When doing so do i fully remove the original one from the system along with the IAT senor or do i leave the original one in and just splice into them?
also on a side note how are the throttle cables secured?
Any info would be great!!!
Here, you remove both and wire it in like so.
Great thanks Alex. Any idea on the throttle cable?
Y3llowCav wrote:Stocker works fine. I'll refer you to this..
http://www.j-body.org/forums/read.php?f=40&i=183438&t=183438
Thanks for the link, that thread has helped me out emensly in gathering and installing parts.
I have to ask though would be possible to post a picture of your throttle cable clamp.The cable is the same but how is it secured. On the stock set-up there is bracket that would hold your throttle and cruise control cables.
I have no cruise control.
You just reuse the stock bracket. It only bolts to the throttle body. The tb is just rotated.
"In Oldskool we trust"
GAH thanks, I hadn't removed the black piece myself, was not sure how it attached.
Thank you
