M62 or saab kit? - Boost Forum
M62 or saab kit?
Friday, June 10, 2011 5:55 PM
Hey,
what is the cheapest one to build. A m62 from 2.0 SS/SC or a turbo kit from saab 9.3 2.0 TC? I think turbo would be great but i dont think there so much saab 9-3 with 2.0 turbo in junkyard.
Re: M62 or saab kit?
Saturday, June 11, 2011 8:26 AM
Saab all the way baby! If you search around enough you can find everything you need.
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
Saturday, June 11, 2011 3:53 PM
Saab setup ftw!
Saturday, June 11, 2011 6:10 PM
I'm actually going to say m62.
Less fabrication involved, for the Saab kit you'll need a downpipe fabbed up, and if you go intercooled then you'll be fabbing the plumbing for that as well. Extra modifying like this will obviously cost more. I also personally think there are more quantities of m62 kits floating around so your chances of finding a good price on one. Honestly, I can't say that with complete certainty, as i never really looked for or priced out saab kits, but I know for a fact on sites like cobaltss.net, complete (or close to) m62 kits are a dime a dozen.
Saturday, June 11, 2011 8:03 PM
strat81 Online
i'd have to agree on the m62... it's a bolt on affair... no worry about running cold side piping or oil feed and return lines. unbolt your stock intake mani, bolt on the new mani and m62 and your basically done.
if you want more power, there's still alot of room to build. are you going to make big numbers like some turbo setups? no, but you're not going to make big numbers on a saab setup either.
Saturday, June 11, 2011 8:11 PM
Well, i think both of them can achieve the same power. I will just look at the price and see which one will be the easiest to found!
Thanks for help!
Sunday, June 12, 2011 5:44 PM
seeing as he asked what cheaper
M62 will be cheaper
whats better get the saab setup
mind yo uthe M62 could be just as expensive if he runs the incooler feature for it
JBO since July 30, 2001
Sunday, June 12, 2011 8:28 PM
M62 is cheaper and easier. both will make the same power for about the same money up until what the stock internals hold and the mp62 will make more torque. AND most importantly the blower is easier to tune for.
Sponsored by: Kronos Performance
Monday, June 13, 2011 10:16 AM
My tig welder runs on about 2 beers per hour so fabrication costs were pretty low for me. Probably paid roughly $800 total for my Saab setup.
Monday, June 13, 2011 10:25 AM
I went m62 and im still under a grand after buying the blower, manifold ,heat exchanger, coolant pump, injectors, brackets, ls1 throttle body, and belts. But I got awesome deals on cobaltss.net
"It's called reading! Top to bottom, left to right... a group of words together is called a sentence. Take Tylenol for any headaches... Midol for any cramps."
Thursday, June 16, 2011 4:05 PM
Agree, since he said cheapest, in the long run there are just more M62 parts around with which to piece together a kit. Want more power? I'm seeing used TVS blowers going for under 1500 these days, hell even in our own classifieds.
Whatever you choose, just don't cheap out on supporting mods, like a good exhaust, good tuning and adequate cooling and fueling for whatever set up your running.
