On the LSJ belt system, which one is the tensioner and which one is the idler? My pulley where the old tensioner was (before SC swap) just started squeaking and I want to get the right part. I think it's the idler but I'm not 100% so looking for confirmation.
The idler is where the stock L61 tensioner use to be. The LSJ tensioner looks like this:
thats what i thought.. thanks Tinkles
Can anyone confirm that this is the right pulley? Dayco part #89070 64mm diameter.
There is no aftermarket pulley for that tensioner, it is a dealer only part and you have to buy it with that piston too which make sit cost 200 bucks. Best bet is to buy one of the OTTP pulleys.
Sponsored by:
Kronos Performance
Sadly Leafy, I found that out. I think I've got part numbers for replacement pulleys, but by the time I found some with the right specs the parts store was closed. I'll be headed there first thing tomorrow.
I got it all situated. I bought 2 pulleys and replaced both of them since I was in there already. Gates part numbers 38009(76mm x 17mm x 25mm) and 38008 (70mm x 17mm x 25mm). NAPA numbers were the same. They are a little bigger pulley than the OEM, but I'm running a 3.0 SC pulley. I can't guarantee it will work with bigger SC pulleys. A little bit of grinding was needed to ensure they didn't rub.
