Dyno day for my Sunflower! - Boost Forum
Thursday, November 04, 2010 10:09 AM
Its finally happening! My Sunfire is going to have dyno results just shortly! We are at the shop right now and in the process of tuning.
Ill keep everyone posted!
Re: Dyno day for my Sunflower!
Thursday, November 04, 2010 11:40 AM
Sweet !!! Hurry up!
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
Thursday, November 04, 2010 12:24 PM
Nice, did you come up here to Columbus?
Thursday, November 04, 2010 12:28 PM
TEASE!!!!
I <3 JGM
I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
In Loving Memory of Phil Martin December 14 2005
Thursday, November 04, 2010 12:34 PM
not done yet!?!?!?
Thursday, November 04, 2010 12:47 PM
Dyno tuning at Dynotune Motorsports in Columbus. So far I'm over 300 horsepower and torque. Not quite done yet.
Thursday, November 04, 2010 2:39 PM
Well goddam.
Thursday, November 04, 2010 5:51 PM
My gawd, still no done? Wth roofy
Thursday, November 04, 2010 6:48 PM
i hope you get up there man.. my le5 l61 hybrid should see 360+..
LE61T PTE6262 Powered
Thursday, November 04, 2010 7:11 PM
Final results! 307.7 horsepower and 316.5 torque at 16 psi!. had my wastegate gasket blow out and my intercooler is pretty much maxed out on flow. When i fix those ill be able to retune for more power. Will post dyno sheets when I scan it. It runs almost perfect and idles really good, especially for having 80 lb/hr injectors.
Thursday, November 04, 2010 7:15 PM
Awesome!
P&P Tuning
420.5whp / 359.8wtq
Thursday, November 04, 2010 7:16 PM
Oh, and it was an intense dyno and tune session. About 8 hours total, most of which was spent on idle tubing and part-throttle driveability. There's alot more in it once I get the minor things taken care of. At WOT at 16psi its seeing around 60% injector duty cycle.
Thursday, November 04, 2010 7:24 PM
16 psi and only 307? is it a small turbo?
Thursday, November 04, 2010 7:31 PM
20G Mitsubishi, but I'm running the generic eBay intercooler that I've had since I boosted the car. Its heat soaking and running my IAT's really high and causing some knock. We are being very cautious with my tune until I get it all sorted out. And my wastegate gasket blew out causing boost to fluctuate some. It'll be better come springtime. I'm aiming for 400 horsepower to the wheels.
Thursday, November 04, 2010 7:40 PM
thats where I should be on me LE5 bottom end. Running a large frame t3t4 I should see 400 on 16
Friday, November 05, 2010 4:29 AM
Congrats Roofy! Good show!
Friday, November 05, 2010 5:38 AM
Good numbers man. That intercooler must be really holding you back, a really MHI 20g should be making around 380-400whp at those boost levels....good numbers though. Get that intercooler replaced and go back for MORE!!!
Friday, November 05, 2010 8:16 AM
Yeah I think I've pushed the old eBay tube and fin intercooler as far as it will efficiently go. 307 horsepower out of a knock-off isn't bad at all once I get a good bar and plate on there, I should be able to run moreo timing and make more power at the same boost level. Thanx for all the good comments!
Sunday, November 07, 2010 1:21 PM
What compression ratio are you running? I would imagine depending on how bad the ebay i/c is you should be able to put down an additional 20-30whp with an upgrade
Sunday, November 07, 2010 3:55 PM
Nice man
Sunday, November 07, 2010 4:16 PM
Way to go roofy. I'd love to see numbers like that out of my slo cav.
Monday, November 08, 2010 9:07 AM
oldskool (eco meatcake) wrote:What compression ratio are you running? I would imagine depending on how bad the ebay i/c is you should be able to put down an additional 20-30whp with an upgrade
Wiseco 8.9:1 pistons. The problem is at higher boost levels, the intercooler isn't cooling efficiently and causing my IAT's to climb really high, resulting in knock. I already fixed the wastegate gasket and the boost is consistent now, so it'll be easier to retune next time.
And as promised, my dyno sheet!
Tuesday, November 09, 2010 6:07 PM
Well, I went to go replace my wastegate gasket tonite and found that my Turbo inlet gasket and downpipe gasket are blown as well, so... damnit. oh well, at least I know there is alot of room for improvement from simple things, its just a PITA to harve to take everything apart again.
Thursday, November 11, 2010 8:50 AM
