im running a t3 turbo set up and i was wondering what size injectors i should upgrade to, stock internals and im about to order up a fuel pump and injectors. just ordered my meth injection kit. so any ideas or any input would be great
If you only plan on running 8 pounds, 42 lb/hr would be fine, and then you could up it a bit in the future.
ya i dont want to push over 12psi. not a daily driver but it is my toy. any comments on msd comp. injectors.
that was everything i needed to know, and looks like rc makes some nice stuff. thanks man
i was boosting 16lbs with my 42trim turbo with 42lb injectors at only 40 percent running a 11.0 AFR
running rich? turn the boost up
buy my 42lb bosch for 30 bucks
they can be your problem now
"they can be your problem now" <---- not the best way to convince someone to buy something lollll
opps, did i write that? i wwas just thinking it
