H/E Coolant Mix - Boost Forum
H/E Coolant Mix
Wednesday, May 05, 2010 12:49 PM
What are those the the H/E running coolant wise?
Straight coolant? 50/50 coolant/water?
ANy other options?
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
Re: H/E Coolant Mix
Wednesday, May 05, 2010 3:48 PM
I'm gunna say mine is around 80 coolant, 20 water right about now, seems to be working good.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
Re: H/E Coolant Mix
Wednesday, May 05, 2010 4:24 PM
when it stays above freezing I'm 100% water but when it gets below freezing I'm 50/50
Re: H/E Coolant Mix
Wednesday, May 05, 2010 8:43 PM
I'm about 80% water 20 coolant.
Coolant is more for the lower freezing point (antifreeze) anti corrosion and to lubricate the water pump. So if your in a warmer climate above freezing I would use mostly water.
13.3 @ 106 mph Cammed
Re: H/E Coolant Mix
Thursday, May 06, 2010 4:56 AM
Just to chime in ..... Is anyone using "Redline Wetter Water"?
I put it in my DD just for giggles and it dropped the coolant temp by like 2-3 needle widths on the gauge.
I have a 96 DD and the gauge would read completly vertical (middle of the gauge)
now its a little to the left (on the cooler side)!
It actually worked .....
I might try it in my Boosted 2200.
If i dont like it, my drain is very easy to get to on my custom radiator.
Re: H/E Coolant Mix
Thursday, May 06, 2010 5:04 AM
I run 50/50 in the winter. I plan on running water and water wetter this summer in my cobalt. That coupled with an ice box should help things cool, especially at the track!!
Re: H/E Coolant Mix
Thursday, May 06, 2010 7:20 AM
Good info, I live in md and it warmer now, Maybe i'll do 90% water and the other 10 coolant, or the water wetter! can you buy that or do you have to order it?
Re: H/E Coolant Mix
Friday, May 07, 2010 11:53 PM
advance and auto places have it....
http://www.cardomain.com/ride/2623318
Re: H/E Coolant Mix
Sunday, May 09, 2010 3:05 PM
slvrblit wrote:I'm gunna say mine is around 80 coolant, 20 water right about now, seems to be working good.
please say you mixed up your amounts ? 80% coolant isnt gonna cool very well , water is alot better at pulling the heat out than coolant
60-75% is where id max winter mix , and even then id rather 50/50 or higher water content and water wetter or similar
Re: H/E Coolant Mix
Monday, May 10, 2010 3:39 AM
windshield washer fluid...low freeze point...mostly water...works for me.
Re: H/E Coolant Mix
Monday, May 10, 2010 4:40 AM
Serious?! Doesn't the cleaning agent or solvents cause any problems?
Re: H/E Coolant Mix
Monday, May 10, 2010 5:50 PM
Jbdy04 wrote:windshield washer fluid...low freeze point...mostly water...works for me.
Interesting.
We had a 50/50 premix jug of antifreeze sitting in the garage, so i just used that.
Re: H/E Coolant Mix
Monday, May 10, 2010 7:46 PM
strat81 Online
i'm planning on 50/50 with a bottle of water wetter for good measure.
also noticed that it dropped my operating temp when i threw it in the rad.
Re: H/E Coolant Mix
Monday, May 10, 2010 9:18 PM
ive tried just dexcool as the factory has, dexcool with redline water wetter, straight distilled water with redline water wetter
not a bit of difference between any of them, i thought running straight water would be my salvation at the bash last year, didnt do a damn thing for me
