Just wondering where everyone is purchasing their fuel injectors... I'm running the injectors from a GTP and wanting to hopefully upgrade when I put the larger turbo on.
"You can only feed them semen for so long before their legs fall off."
i order through myself lol
What cha think??
Clicky!
you will need ev1 adaptors as well, i believe on that site the ev1's are called jetronic. email them and they will get you set up 100% i called them and talked with the guy and he walked me through it. he will have all the adaptors you will ever need to get them wired in right.
and those injectors will be a few mm short but people have been using them with no problems.
I got mine from zzp with the ev1 conncetors
So nobody has bought any of the RC Engineering injectors?
Just curious.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Misnblu wrote:So nobody has bought any of the RC Engineering injectors?
Just curious.
i was going to but they were not big enough for what i wanted. i think they stop at 750 for high impedance
Yeah, I don't need anything quite that large and was looking at some of the 45 pound or 450cc injectors for my M45 build.
I thought that RC would be one of the better companies to go with when it comes to injectors and some that can be rebuilt if necessary.
Misnblu.com
yeah if i didnt have 5 people interested in mine already i would suggest them. I just know RC's are expensive too. but they are a good company to deal with. i like mine and the company i went with because he told me if they were not big enough, he would bore them out and make them big enough. basically, last set of injectors ill ever buy.
i have some RC injectors there at my garage they are 37lbs they work great when i had them on
ok here is a question for ya...i have just the stock 2.4 twin cam..how big can i go with injectors..on my motor??
I need to find some 750cc injectors that fit a cobalt, as I have modified my fuel rail for them. I am planning on running rc ones if I can find ones that fit.
You don't.
They're designed for your motor and programmed into the PCM to operate at their peak performance.
Unless you can tune the car with a program like HPTuners then you might be able to play with injectors a bit.
Misnblu.com
Misnblu wrote:You don't.
ok so i would have to have mods done to it then i take it? ok well im loking to get a supercharger, cams, exhuast, bore it out and stuff like that whats ideal for that?
Read the supercharger stickie in the boosted section for some answers to your question. It's all there and was written to give you ideas on what you need to get your car going for your projected boost.
Other than that, keep everything the same but still you can add intake, header, exhaust without having to increase your injector sizing.
I'd also have a look at HPTuners because without it, you'll not be going too far with your boost wishes.
Good luck with it.
Misnblu.com
