Any tips/tricks for installing the intake manifold support bolt(on the bottom of the manifold)? Im assuming that i have to use a long extension and go between the alternator and block.
Also i have the stage 2 belt and a 3.1" pulley. They dont sound like they mix to well. I believe its the stage 2 belt, cuz it was on a balt with a 2.79" pulley. Do you think i'll be able to get away with it or should i grab a stock belt?
Lastly does anyone have a pic of the belt clearance near the lower overflow tank hose?
Trevor Mullins wrote:
kind of like a screwed up kids sing along
pete the anal monkey lived in my bum..............
best epiosode of barney ever lol
if it is a stage 2 belt it would have 6 ribs on it of course and one would need to be trimmed off to work with the L61 pulleys.
As far as the clearance it is not much; less than an inch sometimes.  Having non-stock motor mounts helps a lot with that issue.
yea may get away with using the stage 2 belt with the 3.1" pulley, as for the the support bolt  i got under the car and used a ratching wrench i found it easy that way.
there was supposed to be a support bolt wasnt there... dont have it lol..
as for clearance, not really too much, ill see if i can find a picture, if not ill take a new one when i get some time.  im using a stage 2 belt with the 3.0 because the stock one slipped so you should be fine
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP  333.6 WTQ [10.1 AFR]
For the bolt I went from the top with a wobbly socket and extension.
The belt if you can get it on I'd say use it. No chance of slip lol.  I'm thinkin of switching to a stage 2 belt myself. Still not convinced I dont have belt slip with the stock belt and 3.0 pulley.
I just zip ties all the hoses together .  Its still close  but should be ok
I used a stock belt with my 3.0 pulley, never had any slipping problems
I zipped tied the hose away from the belt, be carefull with the lower AC hose, I had to replace mine because sometimes under acceleration the belt  would hit it and eventually wore a hole into it.
Bah, if that happens i'll just remove the A/C.  I have windows....
evilmonkitar wrote:there was supposed to be a support bolt wasnt there... dont have it lol..
I *might* have a spare bolt that would work.  I'll know for sure tomarrow/today(wednesday).
I cut a rib off the belt i have, so we'll see if it fits.  I also do have RKsport upper and lower engine mounts in the car and TTR tranny mounts that i should install(since the car is already apart).
The belt is going to be a tight fit. As for the a/c line, just bend it out of the way. Zip tie the coolant hose to the core support.
I'm only seeing just over 10psi with the 3.0 pulley is why i say i'm not convinced I dont have belt slip.
ecotecpower wrote:I'm only seeing just over 10psi with the 3.0 pulley is why i say i'm not convinced I dont have belt slip.
10 psi is a little low. On my 3.0 I was at 13-14 psi with a full 2.5 exhaust, alky and intercooler.
I have one part that i cant find yet.  I also havent had any luck at the dealership.  I need the plug for the stock Cobalt SS/SC heat exchanger pump.  Even a part number will do.
(Tom) S/C Fire wrote:ecotecpower wrote:I'm only seeing just over 10psi with the 3.0 pulley is why i say i'm not convinced I dont have belt slip.
Think the altitude here and 2 1/4" exhaust is killing me.    Sorry for the thread jack
Dont worry about it, just get me a plug for a Cobalt SS/SC H/E pump and we'll be even.
this should be the connector  for the heat exchanger #89046833 this is what my work gave me for the connector  number.
Tinkles wrote:Any tips/tricks for installing the intake manifold support bolt(on the bottom of the manifold)? Im assuming that i have to use a long extension and go between the alternator and block.
let me know how that goes, was thinking of getting a 3.1 or a 3.0 pulley.
i have 11.2 on a stock pulley,
 13.22 @ 105.2
my zzp 3.1 pulley seems pretty tight on the stock gmperformance kit belt. i have no clue how it compares to the cobalt belts. im seeing 11psi out of it w/2.5" full exhaust. was at 13psi with my old 2.25" cat-back exhaust.
wow i see 11 now with the stock pulley header and 2.225 cat bac
z28guy(KGM BEOTCH)
did that part number work for u tinkles?
Tinkles wrote:I have one part that i cant find yet.  I also havent had any luck at the dealership.  I need the plug for the stock Cobalt SS/SC heat exchanger pump.  Even a part number will do.
You can also use any bosh style injector plug, could easily swipe one at a yard or get one onilne at summit racing etc for cheap...
z28guy wrote:wow i see 11 now with the stock pulley header and 2.225 cat bac
I'm only seeing 12psi w/ the 2.8 pulley... Remember boost is only a measure of resistance.  Every engine, regardless of modification will flow at least a little differently.
the heat exchanger pump connector is just a standard bosch injector connector. Any parts store will have this. $5 vs $20 At the dealer.
Ok i'll look for one tomarrow when im out on a parts run.
Also this damn dual pass plate in becoming a PITA.  I just need another 1/4" of clearance for the "T", or i need to find a "Y" fitting.
I should have gone turbo....
Edited 1 time(s). Last edited Thursday, March 12, 2009 9:04 PM
Tinkles wrote:Ok i'll look for one tomarrow when im out on a parts run.
lol.. thats why i told myself the next car i buy is going to be boosted already.. wont have to deal with crap like that lol
What vehicles run Bosch injectors?  Im having trouble finding one locally.
