Searching has yielded nothing.
Looking for 42lb/hr or close.
If you're interested, I can sell you my 44lb injectors (same as link above)... Used for one season. I just got a Port Fueler, and it's pretuned to work with the 36lb injectors so I'm toying with the idea of getting those instead of having to tune it myself.
PM me if you're interested.
Why only 42lbers. They are safe for about 250-260 crank hp. You should have just stuck with the 60's you sold recently...
^ That's really all I want in terms of power.
I don't think there are any direct replacement 42 lbs except for the gm stage 2 injectors.
zzp has a deal on a set of 4 42lb injectors with clips for less than 160 now.
Now that I think about it 60 lb injectors are pretty big for the s/c's. 42's should be fine for a little more than 260 crank. Correct me if i'm wrong.
I made 309whp on 42's with the 255 walbro fuel pump..
i made 238WHP on the stock cobalt SS injectors and stock fuel pump, gm cal :\
12.33 @ 111.67 mph [Oct 2009]
