I searched and only pic i could come up with was the hahn racecraft motor on the stand with the downpipe. Does anybody have in car shots of a 3 inch downpipe on a ecotec?
bump on this too
I have pics from my auto LD9.. You can get the idea, no matter the motor.
Unless you need pictures of it on a manual car.
i need one for a auto car so it will work for me
Here's a pic of the setup I have that's coming off the Cavalier and being sold. I don't believe the 02 housing is 3", but it does neck down to help keep TQ up then opens up to 3". One of the really nice custom pieces HAHN did on this kit.
Thanks fastcavz24 Thats what i wanted to see i ordered two stainless u bends cause from were the turbo is mounted it looked it was going to have to be an s shaped downpipe but i wasnt sure. Whitecavy post them for the automatic so we can get an idea how it will be for 03lssportblue.
I posted a few pics in the photos forum
Here you guys go.
Bolted up
2012 numbers - 4SPD
AUTOMATIC!!
wow thanks alot man that helps a bit but quick ? did you have to remove your AC to run the pipe ???? and any real clearance issues?
03lssportblue wrote:wow thanks alot man that helps a bit but quick ? did you have to remove your AC to run the pipe ???? and any real clearance issues?
Np, nope we actually fabbed up the turbo and piping with the A/C still attached.. I only took the AC out months after we got done with the turbo.
The only issue with this downpipe was when it came to my Vband clamp that connects the end of the DP to the rest of the exhaust.. We had to cut off part of the heat shield under the car just where the DP goes under the firewall.. That is it.. The Vband clamp is too bulky to fit with that shield.
Once I get my girls camera again, Ill take pics of the underside of the car so you can see more clearance.
2012 numbers - 4SPD
AUTOMATIC!!
WHITECAVY wrote:03lssportblue wrote:wow thanks alot man that helps a bit but quick ? did you have to remove your AC to run the pipe ???? and any real clearance issues?
would be appreciated
bump
I have some of my 3" downpipe. Well it's actually a 4" reduced to 3". but it's on the driver's side. if you think they'll help you, i'll post em. i'm auto as well
http://jbok.org
imacav wrote:I have some of my 3" downpipe. Well it's actually a 4" reduced to 3". but it's on the driver's side. if you think they'll help you, i'll post em. i'm auto as well
yea would appreciate any pics or info
Still tryin to get a camera
2012 numbers - 4SPD
AUTOMATIC!!
WHITECAVY wrote:Still tryin to get a camera
its cool dude it will be abit before i have my turbo to even test it so no worries
sexy pictures
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
Better late than never right? lol
2012 numbers - 4SPD
AUTOMATIC!!
Its not for a Eco but i felt like posting pics.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
wow thanks guys that does help a bit
dear lord,david. your setup never ceases to amaze me.
i can only hope to one day have as sexy of a system as you.
In the end, we're all just chalk lines on the concrete.. drawn only to be washed away.
Thanks Brad, it was well worth the 2 months the car was down that we worked on it
2012 numbers - 4SPD
AUTOMATIC!!
