What size spring are you guys using in your tial bov's? I know your supposed to go off vacume, I have a boost/vac gauge but I just did some things and may have a slight vacume leak so not sure if its correct. Does the 9lb spring for an idle vacume range of 14-17 sound correct? I have a silver spring, which is there a way to tell if its the 11 or 12lb spring since they both look the same?
I have a blue and green spring in my 44mm which is around 16 psi. Im not sure which way to check which spring.. Maybe ATPturbo.com has some info on there for you.
WHITECAVY wrote:I have a blue and green spring in my 44mm which is around 16 psi. Im not sure which way to check which spring.. Maybe ATPturbo.com has some info on there for you.
Thats for your wastegate
Im not sure which one we have...
Sorry Dave I mean the tial 50mm blow off valve lol, The springs are a bit different than for the wg. I have the small green spring(7 psi) in my tial 38mm wastegate, but need to know what spring people use for the bov which is based off idle vacume pressure.
jmarks82(Bulldog) wrote:WHITECAVY wrote:I have a blue and green spring in my 44mm which is around 16 psi. Im not sure which way to check which spring.. Maybe ATPturbo.com has some info on there for you.
Take it apart for me
Its only 6 allen screws lol
Idle vacuum should always be around 13-17 in/Hg if you don't have big lopey cams. Don't really remember why but that's what every book I've ever had has said.
5K PB: 24:50
10K PB: 54:26
Ok I thought so, mines normally right around 15in/hg at operating temp. So I guess I should get the 9psi spring.
LMAO duurrr. *smacks head*
2012 numbers - 4SPD
AUTOMATIC!!
