ok so i bought the supercharger used and there seem to bew some things im missing mainly hoses and hose connectors so i need your guys help to tell me what pipes or hosing i need to go buy or make work please help me out guys. i just finished installing the idler bracket and need to get this stuff done.
http://www.cardomain.com/ride/2623318
if you want the exact stuff head to the GM dealership.
Fall 08 Omaha/western Iowa area meet...
CLICK ME!
You can make your OEM brake booster tube and cruise bracket (I think thats what the lower piece is you circled) work, and Autozone sells vacuum line.......... but "making it work" might be considered a "hack job" by Z yaaaa.........
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
I actualy have that cc bracket in the bottom of the pics if you need it, and cant realy tell what most of the other stuff in the pic is but looks pretty much like vacume line which you can get at alot of stores. And as said the stock brake booster turbe can be cut and made to work.
ok so ill make the brake booster work. which means i will need to buy a couple elbows? and ill buy a couple feet of the vacum lines. and you said you have the bracket ? i def would like it .
People always dogged on, but I've ran rubber for my brake booster hose on 2 cars now with no issues. Not sure if I used the reinforced fuel stuff, or heater hose though.
guys i have a wire coming out of the harness under the starter seems to be a ground i think it has one ground spot and 4 wires running to it in two pairs.
AC Rubber hose works great also thats what im using since i removed my HO mani to go back to Stock
ok i got all that hose stuff done today now all i have to do is finish the wires near the starter there are two that come out of the harness under the starter not sure if they are grounds or what now. one is a lil circle looks like it goes on the starter and then there is one with four wires all connected to one connector. i need to hook those two u in the proper spot then its charger time please help me guys...
Joe Schulte wrote:People always dogged on, but I've ran rubber for my brake booster hose on 2 cars now with no issues. Not sure if I used the reinforced fuel stuff, or heater hose though.
Same here. Forget about that metal vaccum line. Getting your old one out and the new one from the kit in was the hardest part of my install. I am so glad I just ran hose to where it needs to go.
jesterz413 wrote:guys i have a wire coming out of the harness under the starter seems to be a ground i think it has one ground spot and 4 wires running to it in two pairs.
Those sound like the ground wires to me if they are all black and you have 2 ring terminal ends that each have 2 wires going to it.
What was the point of the pic you posted?
The big one that goes from the throttle body to the brake booster.
those are grounds and they piggyback on a bolt on the block.
what is the red, green thing? is this part of the wire? the only thing i can think of is the fuseable link...which doesnt "go" anywhere.
Real pics would probably be more helpful.
14.330 @ 96.37mph
oh no i was stating that last statement . it is where it goes. got everything done to the engine . buying new axles tom . and then everything can go.......
SpeedRacerZ wrote:You can make your OEM brake booster tube and cruise bracket (I think thats what the lower piece is you circled) work, and Autozone sells vacuum line.......... but "making it work" might be considered a "hack job" by Z yaaaa.........
Then what would my 95 be?!
Chris
'02 Z-24 Supercharged
