M62 install help - Boost Forum
M62 install help
Monday, August 04, 2008 9:17 PM
i am putting on my kit and i am at the part where i have to take the plastic tube off the stock intake and put it on the new TB adapter and it said to use the supplied self tapping screw but gives me no part# and i dont see one with the kit.
what did yall use to get it to fit?
Re: M62 install help
Tuesday, August 05, 2008 12:12 AM
also how do u get the belt on
Tuesday, August 05, 2008 3:55 AM
Tanabeo wrote:also how do u get the belt on
get a wrench or vice grip (makes it easier) and push down and sorta back on the tensioner pulley bracket. its right where you shaved a piece of the manifold. 2 people is easier for the job. i put it over the crank pulley last.
my carDomain updated 8/2/08 Boosted at B-day!
Tuesday, August 05, 2008 10:41 AM
My kit didnt come with the screw, or I misplaced it when I was arranging the parts. either way I took the throttle body spacer and the plastic flange thing and went down to the hardware store and bought a screw that fit for 10 cents........ done!
Oh yeah, and keep in mind the throttle body spacer is soft metal (maybe aluminum) dont over-tighten the screw or it will strip.
Edited 1 time(s). Last edited Tuesday, August 05, 2008 10:42 AM
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Tuesday, August 05, 2008 11:07 AM
mine is still not moving.
Tuesday, August 05, 2008 12:16 PM
i put mine over the crank pulley first and the supercharger last. put the tire iron thats with the spare tire in the trunk between the motor mount and motor and press down on the tensioner, but be careful since that pulley is plastic... i broke a piece off of mine cuz i did it at an angle on accident...
12.33 @ 111.67 mph [Oct 2009]
Tuesday, August 05, 2008 5:01 PM
For my belt, I can change the ENTIRE belt without a Jack and only using a prybar.
I do EVERY pulley EXCEPT the AC pulley, with the pry bar I pry down on the Idler pulley with pressure against the SC pulley, once this is done the BOTTOM FRONT AC pulley can EASILY be looped by the slack in the belt.
It is VERY easy with a buddy ready for the slack to loop the AC pulley.
After me and a friend swapped pulleys a couple weeks ago, we then had to swap the belts as his was shorter and I needed it too.
Well it took us about 5mins to swap 2 belts, 1 on each car using the way I described.
I maybe can get a video clip if necessary.
Tuesday, August 05, 2008 5:19 PM
could u take a pic of where u put the bar thanks for the help
Tuesday, August 05, 2008 8:24 PM
while i was trying to get the belt on i saw that there was a hose in the way that runs down to the a/c.... how do i get around it?
Wednesday, August 06, 2008 8:35 PM
I cut mine and rerouted it straight down, I had to add a couple fittings.
I will try to remember to get you a pic tomorrow of the Belt and how my hose is routed.
Wednesday, August 06, 2008 9:11 PM
14.330 @ 96.37mph
Wednesday, August 06, 2008 9:16 PM
BlownBlackZ wrote:
yea i was looking for that pic, i didnt remember what thread i posted that in lol.
if you dont want to take the chance to mess up the side, that bar fits btwn the mount and motor too (meaning you can go a little more left with it)
Friday, August 08, 2008 7:38 AM
thanks its all on now and rdy to go
