Skilz10179 wrote:Whats this BS with "two regular pulls and one pull with a recalibrated Dynojet reading"???
Some of the #'s i've heard form this "dynojet" pull seem unrealistic.
QBE(Qwibby Soon to be Boosted) wrote:Skilz10179 wrote:Whats this BS with "two regular pulls and one pull with a recalibrated Dynojet reading"???
idk how it worked but they used a dyno dynamics dyno and kept saying true power and dyno jet number's...
to me all the dyno jet numbers seemed real and normal..
when their dyno was running it would put huge loads on the crs to where some cars would actually bog down real hard...
Vincent Morris wrote:6.0psi 161 first run
182 2nd run
and 225 on third run with the dynojet numbers.
i had the 9psi spring in there and i the first run was due to an exhaust leak. after that one we did another run and hit the second number just by letting it seal up by expanding haha. also the operator of the dyno said i had a junk tune and was hitting 10.5 throughout the whole pull. so im gonna head down to visit imphat2200 and fetter and let them have their way with my car by the end of summer haha. then he think i can get about another 20 out of it just by tuning then i expect a few more once i get the exhaust leak fixed for sure. i cant wait.
Wade Jarvis wrote:QBE(Qwibby Soon to be Boosted) wrote:Skilz10179 wrote:Whats this BS with "two regular pulls and one pull with a recalibrated Dynojet reading"???
I noticed exactly what QBE said and agree with him on the dynojet numbers seeming about right..
From my understanding all that was changed to simulate the "dynojet" readings was the box where you enter into the dyno the ambient air temp was changed to 140 something degrees. Ask Imphat0260 he knows for sure.
Are you thinking the recalibrated dynojet numbers are are reading higher than a dyno jet or lower or do some seem higher and some seem lower to you?
I am quickly loosing faith in dyno's numbers all together. Unless you dynoed on the same day at the same time on the same dyno with the same dyno settingd it is a joke. Is there no @!#$ standard? No way to calibrate them? I am not saying this because I am unhappy with how my car did, infact I think it did well all things considered. It is just the variation between dynos gets on my @!#$ nerves. XXX amount of whp should be the same no matter what brand dyno it is. To me it is straight up!!
icemike89(not turbo) wrote:Yea I was kinda upset I didnt get to do a dynojet and pretty much wasted a few runs due to my afr's jumping up. They said an 18% increase or so on the dynojet, which would have been around 210whp give or take a few between my few runs; this is without nitrous.
I also found today I had a vacume leak which was is why I was only seeing 5-barely 6psi as opposed to the 8 Ive been seeing. Also had a bad iac sensor which was causing the car to stall.
Wade you get your alchy kit worked out yet? I still have to talk to cooling mist to figure out my nozzle size situation.
John Higgins wrote:icemike89(not turbo) wrote:Yea I was kinda upset I didnt get to do a dynojet and pretty much wasted a few runs due to my afr's jumping up. They said an 18% increase or so on the dynojet, which would have been around 210whp give or take a few between my few runs; this is without nitrous.
I do not see a auto 2.4 with a GM charger putting down 210 at the wheels without help from juice. The auto tranny just sucks sooo much power.
icemike89(not turbo) wrote:John Higgins wrote:icemike89(not turbo) wrote:Yea I was kinda upset I didnt get to do a dynojet and pretty much wasted a few runs due to my afr's jumping up. They said an 18% increase or so on the dynojet, which would have been around 210whp give or take a few between my few runs; this is without nitrous.
There was another auto m45 that ran and made 170 something on the dynojet, and Im pretty sure all they had were the m45,intake,and full exhaust.
The auto does suck, but I have a ttr trans mount, ATI, and have played with trans settings just a bit in HPT which help some. Not to mention I have quite a bit more done than the other car as well. I think with a good tune alone and stepping up to a full 2.5" exhaust over my 2.25" I should get about 20 more out of it. Then I'll also be a bit safer for the spray when I richen it up, but I know I need to put in a smaller shot. I just wanted to see what it could do if it could stay together lol.
icemike89(not turbo) wrote:John Higgins- What kind of dyno were they on? As said different dyno's could give completely different numbers, and cant realy tell which one is correct. All I know is that a timeslip is only the real way to tell, which I dont have any new ones due to the problems with the track sitution at the bash. Like said I didnt make any dynojet runs, but everyone else saw about an 18% increase; even the other auto that ran went from about 150whp to 178 on the dynojet I believe.
Wade- Yea I know the exhaust wont make a world of a difference, but a full 2.5" exhaust is better than my hacked up exhaust that goes from 2.5" to 2.25". Ive talked to sc'd and n/a people that went from 2.25" to 2.5" that said theres a noticeable difference in the upper rpm.
