is anyone runnin 2.5 inch charge pipes and gotten them to fit behind a stock 95-99 z24 front bumper while keeping ac and the carbon canister if so pics would be phenomenal. i will probably just step down to two inch pipe but just thought i would ask first
Umm IIRC the "Carbon Canister" is at the rear above the trailing arm behind the fuel tank.
5K PB: 24:50
10K PB: 54:26
Hypsy (The Trucking One) wrote:Umm IIRC the "Carbon Canister" is at the rear above the trailing arm behind the fuel tank.
Yeah it's like that on the 00+ models, some 99 year models have it in the rear too. Anything before that it was behind the passanger side of the bumper.
yeah i have a 98 its under the bumper passenger side
Well no @!#$. I learned something new.
5K PB: 24:50
10K PB: 54:26
Its possible. I have seen a few that have done it. You just gotta be creative.
run it right below the wire harness that runs below the "canister" and back around the compressor then up by the alt and on top of the ac lines
Now this is a 2000 but may help you a little.
Mine is the same as above...
-- MyZcar
thanks for the help. hope to be up and runnin soon
for the 00 did you keep your fogs? the way mine sitts, it's looking like a non z24 bumper would work the best!
I didnt feel like trying to route around teh fogs so I just cut them out. The bumper was junk anyways.
Kyle Phillips wrote:for the 00 did you keep your fogs? the way mine sitts, it's looking like a non z24 bumper would work the best!
I have a base bumper on and there is no problem by the foglights but we put my buddies z bumper on and it cleared them just fine.. so either bumper
should work
-- MyZcar
nope i had to cut the fogs out, aww well it looks sick
IM running 2.5in charge pipes with no problems it can be done
