ok so im looking for a set of fuel injectors for my turbo motor im building. already have my fuel pump ordered. so i have noticed that most ppl are using RC Engineering fuel injectors for their setups but my ? thou it may be dumb but what is the difference between peak and hold VS saturated injectors ????
"puts on his flame suit "
high impedance VS low impedance
whiteboyz24 wrote:high impedance VS low impedance
right, you need to measure the resistance between the 2 pins on your injector to figure out which ones you have.....my guess is high, that will read AROUND 15 ohms.
High impedance = saturated
Low impedance (2-4 ohm range) = peak and hold.
ok so i would assume then for my eco turbo build i would want high impedance then ??? or am i missing something
bc im looking to make about 400hp when the full motor build is all said and done
you want whatever type is already in there.
measure the resistence between the 2 pins that the plug plugs into.
ok cool i will take out a injector and check them tonight....
thanks alot man
Smart money says they are high imp. injectors.
John Higgins wrote:Wrench Monkey wrote:Smart money says they are high imp. injectors.
X2
Basically they are without a doubt High Imp. injectors.... as far as i know all jbodies after 99.5 had high imp injectors.
if i were to look up the part # of one of my injectors would that tell me or should i still test it ????
You have a 2003. They're high impedance.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
They are high, I screwed up on my order and got low. But a resister box from a 91 accord solved that little @!#$ up!!!!
491whp, 393wtq
11.93@ 127mph
Raven Autosports (902)850-3330
well that works out rly well
thanks everyone for the help
