Has anyone actually been able to use this manifold with out having exhaust leaks.
If so what gasket or combination of gaskets did you use?
mitch and i both have that same manifold
there are zero problems with it
the gasket i used is from the saab dealer and i'll be sure to get you the part # when i leave work
the stock eco gasket ive got sitting here has the same port layout as that manifold , and it is from a cavalier
far as i know , just block on the ports on the outside of the manifold
Use the exhaust manifold gasket from a 2004+ Saab 9-3 with the ecotec engine without air injection
Only 2003 came with air injection
maybe not... just called a saab dealer they said the 04-06 saab 9-3 B207R wo/air injection gasket number is 12786717
I wish I could help ya out Lee.
no worries mate..
we'll get er figured out and this post will aid someone else down the road.
