The stock cobalt injectors.... either 32 or 34 I believe we all have established fit into the 02 rails no issues. Does anyone know if the Stage 2 injectors (42's i believe) Also fit without modification?
why not?
12.33 @ 111.67 mph [Oct 2009]
I mean as in using the stock harness and what not just like you can do with their stock injectors.
Stage 2 injectors are the same and have the same plug as stock LSJ injectors.
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
Thats what I was thinking about doing in the future. I have an ld9 but all I have to do is slot the bolt holes a bit since the lsj's are shorter. I dont see why the upgraded stage lsj inectors wouldnt fit right in and plug up since their replacements for cobalts.
I asked because I thought that for the cobalts to use the 60s they love to use you have to use a separate harness....unless those 60s they run aren't from a gm stage upgrade....now that i think about it I don't think they are.
