Scarab (Jersey Jay 1.8T) wrote:Eh, you may need bigger than 320cc even for just 250hp.Whoops, I meant to say 320cc min.
Scarab (Jersey Jay 1.8T) wrote:Ask Notec what happens to pistons when its not
madking411 wrote:okay, this all sounds pretty good to me!![]()
So, im guessing that also means i should try to get my hands on some FORGEDpistons before boostin too? Just in case my tune is at first a lil crazy?
Scarab (Jersey Jay 1.8T) wrote:...assuming the motor is built correctly. I've seen a couple recently that have seized because the bores were not large enough for the forged piston expansion.madking411 wrote:okay, this all sounds pretty good to me!![]()
Overbuilding only ever hurts the wallet. Its always a good thing to have an extra safety cushion, so things like forged pistons, slightly bigger injectors than needed, etc, definitely don't hurt.
Kyle Sheldon wrote:So if one was to build a boosted 2200 motor to handle less than 300, should you go with something like eagle rods, or will forged pistons on stock rods be good, for 200-250 whp?I would leave the bottom end stock; pistons are incredibly expensive. Get a .030" Cometic head gasket and ARP head studs, but don't worry about anything else. Just take your time with the tuning and slowly work your way up.
This is all news to my ears, i thought the internals where relatively weak, but the block was strong as hell.
OHV notec wrote:Kyle Sheldon wrote:So if one was to build a boosted 2200 motor to handle less than 300, should you go with something like eagle rods, or will forged pistons on stock rods be good, for 200-250 whp?I would leave the bottom end stock; pistons are incredibly expensive. Get a .030" Cometic head gasket and ARP head studs, but don't worry about anything else. Just take your time with the tuning and slowly work your way up.
Kyle Sheldon wrote:Pay for some decent tuning first, that BEGi FMU won't last long...OHV notec wrote:Kyle Sheldon wrote:So if one was to build a boosted 2200 motor to handle less than 300, should you go with something like eagle rods, or will forged pistons on stock rods be good, for 200-250 whp?I would leave the bottom end stock; pistons are incredibly expensive. Get a .030" Cometic head gasket and ARP head studs, but don't worry about anything else. Just take your time with the tuning and slowly work your way up.
Well thats a pleasant surprise. I may do just that. I have a spare car now, and i've been wanting to get a new turbo and bump up the PSI a bit, make some more power.
Sorry to thread jack by the way.
Trent Brotzler wrote:The piston skirts were destroyed, I doubt it was the rings,Quote:
This is most likely caused by improper installation of the piston rings. If you buy forged pistons MAKE SURE, you file your piston rings to the proper specs of your motor! If I were you I would have a shop do the piston installation.
