will my stock injectors damage my engine???? i won't be shooting more than 7psi of boost maybe i'll be boosting more later but i need to know before i install the turbo.
real what is a fuel system FAQ, should answer everything you need
another tip, PSI doesnt matter when it comes to injectors, it's HP goals
so... it doesn't matter????? my stock injectors will handle at least 8-9 psi???
The new to boost FAQ as well
Injectors dont damage your engine, its the lack of fuel under boost that does the damage
Your stock injectors wont support even a well modded NA car much less boost, lets put it this way even 310cc injectors are maxed at about 5psi
If you want to run 8-9psi your going to need 370cc or 440cc injectors, if you try running stock injectors on 8-9psi your going to either damage your motor and or your stock injectors (probably both)
Save yourself future troubles now and buy the right injector
thanks, well i'm gonna have to nuy them new then, i asked this because of what i have heard but i wasn't sure this clears my thoughts
how many cc are the cobalt ss green injectors
I have a 2.4L rail with cobalt ss/sc injectors and a accel afpr for sale.
for how much r u selling the injectors????? because i was thinking on getting the injectors of a 3.1 dohc cavalier 1994 but if u have them and will fot my car let me know. HOW MANY CC???
What do Ford green tops and brown tops flow in cc's?
Timothy Pietraallo wrote:I have a 2.4L rail with cobalt ss/sc injectors and a accel afpr for sale.
How much do you want for the setup?
