waistgate question - Boost Forum
waistgate question
Thursday, February 07, 2008 9:10 AM
i am wondering the vacume line to my waiste gate were can i run it off of does it have to be off the charge pipe or can i run it to the intake and were does the boost guage vacume run to
Re: waistgate question
Thursday, February 07, 2008 9:26 AM
You could run it off a charge pipe. Most turbos have a nipple off the compressor side you can use. Or you could use a vacuum line as long as it doesn't have a check valve, just so long as the source will have positive psi when you boost.
Thursday, February 07, 2008 9:30 AM
so can i run it rigth off the intake or were else can i run it from becuase i dont have a nuipple in the charge pipe to put it on to it is the 2.4 engine were else can i run it to
Thursday, February 07, 2008 9:43 AM
does your turbo not have a nipple for the wastegate vacuum? that is the best place for it. if it doesn't, it's no trouble to take the compressor housing off and tap it for one.
http://jbok.org
