Whats the difference between turbos? - Boost Forum
Wednesday, February 06, 2008 3:03 PM
http://www.westcoast-turbo.com/turboa.html
Whats the difference between the Garrett T3 Turbo & Garrett T3 "SUPER 60" Turbo
Garrett T3 Turbo
-Rebuilt Garrett T3 Turbocharger
-45 or 60 Trim Compressor Wheel
-.42 A/R (Shown) or .60 A/R Compressor Housing**
-.48 A/R or .63 A/R Turbine Housing Option
-Stage 1 Turbine Wheel
-Internal Wastegate Option (.48 A/R Housing Only)
-Rebuilt Garrett T3 "Super60" Turbocharger
-Super 60 Trim Compressor Wheel
-.42 A/R or .60 A/R (Shown) Compressor Housing**
So if i got the 60 trim compressor wheel on the garrett t3 turbo would it be the same as the super 60 for $60 less?
thanks
Re: Whats the difference between turbos?
Wednesday, February 06, 2008 6:14 PM
The Super 60 is closer to a 65 trim. Why they call it Super 60, I don't know. The two wheels have the same outlet diameter, but the input diameter of the Super 60 is a tad larger.
60 trim = (1.83mm^2) / (2.367mm^2) x 100 = 59.8
Super 60 trim = (1.90mm^2) / (2.367mm^2) x 100 = 64.4
Go Go OG Traction!!
Wednesday, February 06, 2008 6:17 PM
damn...the millimeter units should be inches...grr
Go Go OG Traction!!
Wednesday, February 06, 2008 6:50 PM
so there wont be much of a noticable bifference between power between the 2 then?
Wednesday, February 06, 2008 7:06 PM
here are compressor maps
60 trim
Super 60
As you can see, the Super 60 is a bit more efficient in the higher air flow range. If you plan on running higher boost, then go with the Super 60.
I know a few people with the Super 60, and they seem quite happy with it.
Go Go OG Traction!!
Wednesday, February 06, 2008 7:47 PM
Thanks for that info. I'm trying to learn all the different specs of turbos and that helped with one thing I was wondering.
Wednesday, February 06, 2008 8:08 PM
ok thanks im looking to run between 14-17psi fully built just looking at my options so is that a dicent price for a rebuilt turbo?
Thursday, February 07, 2008 4:56 AM
Im gona be using a t3 super .60, I only want around 7psi though. For the amount of boost you want Id go with something bigger and bb, like a gt series.
Thursday, February 07, 2008 8:12 AM
the thing is there really isnt that much room for anything bigger than the super 60 in the 2200
