Hey, i was wondering if anyone knows at what point the stock head gasket will fail under boost? Specifically the 2.3L felpro, but i will take 2.4L input as well.
I know in the past people have went FI on bone stock motors, and I am interested in the failing point of the HG, 10.0:1 pistons/rings combo. Thanks
Also, I understand that detonation is going to play a large role in these items failing, so lets pretend, on a motor that has been properly tuned, when would these items fail.
M90'd Built LGO-15 PSI
http://webstarts.com/quadper4mance
spyhunter blew it somewhere around 13-14 I think
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
yea i blew my felpro out at 13lbs as well
Is that with or without Head Studs?
thank god for the ecotec... gm 3 layer mls ftw
LE61T PTE6262 Powered
Blew the fel-pro @ 14-15 psi, stock head bolts.
-Chris-
-Sweetness-
-Turbocharged-
Phil aka QBE wrote:thank god for the ecotec... gm 3 layer mls ftw
Amen
Street-Legal 2003 Sunfire 10.58 @ 139 MPH
Should have picked that up rather than our 2 layer mls. Its all good
I hear the 2.3 fel pro likes to let go around 10 PSI. The graphite gasket should hold up much better. I have seen more fel pros burn out that graphite ones. Ill be rebuilding with a graphite gasket.
I've used a Felpro with ARP studs and pushed over 300whp without a failure.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
all LD9;s
95 Z-24 LG0\W41, 13-17LBS, still going (GM gaskit.).
Chris
'02 Z-24 Supercharged
K. Vega,Now With Vitamin Boost wrote:Should have picked that up rather than our 2 layer mls. Its all good
the l61 headgasket is good for 400 hp. That thing is a beast.... I had a hell of a time prying it off my old motor lol
yea thats What I've seen. If I were building this motor I would have went with the 3 but for a head job like I did I just went with another Oem.
