i am just wondering were do i run the vacume lines for my rfmu and my duel boos and blow of valve and stuff like that would i just split into another vacum sorce and go fromt here or twhat do i do i am new to this so the help is apretiated thank you
or a diagram that i can work of of if any one knows of one out there please
You can run it all form the same source using T connectors. Or you can purchase a vacuum distribution block and go that route.
2004 Cavalier coupe, 5 speed, White
GO
Hahn Stage 2, Eagle rods, Wiseco 8.9, SS Valves, Dual valve springs, valve job, Ti seats and retainers
spec stage 3, Fidanza 7.5lb flywheel, Short Shifter
Slotted and dimpled rotors, EBC green stuff
SHOW
VIS EVO CF hood, KOBE KAM 5 17", Nexxen N3000, Ebay Black tails and filler, 5% tint
Gold line springs, Tokiko D-spec struts
ELECTRONICS
Kenwood in-dash DVD and Navigation, single Kicker CompVR
http://www.cardomain.com/ride/2974835
I am not sure what a duel boos is or what engine you are working on otherwise I would try and help you out. By the way vacuum is not spelled vacume.
i no it is spelled vacuum sorry man it is a 2.4 i am working with
i dont know i looked for the vacuum diagram and i couldnt find it sorry
I used a T fitting from the stock FPR for the BOV.
sorry man i didnt look on the second page
