hey guys i searched but couldnt find anything. What gauges are needed to go with the gm sc? obviously boost thats obvious but what else air/fuel, trans temp? thanks in advance
nothing is
needed.
I will sell you the boost gauge cheap. I have one used but still in mint condition 2-1/16 size.
To the OP
None are needed .
Boost is nice but mainly just to satisfy your own curiousity.
Oil presure is a good one. But if you keep an eye on your oil and keep full you should not have any problems. An oil pressure gauge will alert you long before tthe light comes on on your instrument cluster. So it is definatly a good idea.
A wideband air fuel would be the most important if you ask me since running lean could cause you to blow a ringland or worse. A narrow band air fuel gauge is all but worthless.
A trans temp gauge would be good. But I would spend money on a transmission fluid cooler first. Then after you do that there is not a whole lot you can do to keep the trans temp down. It would just be a good indicator of the obviuos that is is time to stop beating on your car and let it cool down some.
Pyrometer or EGT gauge is I would not worry about with just the GM sc setup.
Any gauge is worthless though if you do not monitor it enough to notice a problem right away.
im running:
Boost
pyrometer
wideband/aem
and where the hvac goes
i have:
voltmeter
oil pressure
and coolant temp(for s/c intercooler)
