Well as some of you may have seen my other post.. i got a fully built engine for the Twin Charged set up... im looking to run about 15psi... And i have always been leaning towards getting a MSD set up... but never have...
For thoughs who have it.. how much of a difference did it make?
Also which one would i be needing? i have been tuning with HP tuners so i dont need one that adjusts timing... i just havent been able to find out clearly what the difference between all the modles are and such..
Any one with info on this let me know...
And I remember seeing some one who actually had raplced the entire IDI cover and just ran wires to the spark plugs (well kept the cover just drilled 4 holes for the wires..is this how it is set up ? or was it just a custom one?
 The First Twin Charged jbody
I'm running the Team Green 2.2 coil conversion + MSD DIS II non programmable...
Utilizes MSD coils, coil adapters, oem GM ACDELCO spark plug wires and an MSD-DIS2... in all honesty just the coils ALONE made a huge difference over stock, the MSD just helps with more power as well as multiple spark discharge to ensure a complete burn.
Keep in mind stock coils are limited to I think 20,000 volts whereas the MSD ones can go to 40,000, which is around where the DIS2 maxes out.  DIS2 with stock coils is a definite improvement but if you want maximum sparking capabilities go with the MSD coil setup too.
Lastly, what plugs do you plan to run?  I've used both the GMSC 1 step colder as well as a 2-step colder GM DELCO plug... good results on both.  (Gapped at around .035)
Good luck.
-Chris-
-Sweetness-
-Turbocharged-
SweetnessGT wrote:I'm running the Team Green 2.2 coil conversion + MSD DIS II non programmable...
Good luck.
-Chris-
I have looked every where but i cant seem to find a set up that would work for the 2.4L? do you have any pictures of your set up?
not 100% sure what plugs i have in... when i got my car tuned he changed them so i couldnt tell you for sure...
i have the team green setup and step 1/2 colder plugs and it runs awesome
I ran a DIS-2 plus on my 2.4 years ago, worked great and I never had any ignition issues.  There was a write up on this site for it but that was almost 6 years ago now and I don't remember now.  I do remember it wasen't hard and wired in under 30 min, everything wires into the ignition module under the cover.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
ask whitecav (david)  he is running an MSD ignition on his 2.4 currently.  he will let you know everything about his setup
