Hey guys, i'm having one hell of a battle with getting my alky injection kit to stay working. I've rewired it a few times and finally found the stock relay the kit came with was bad, i found this out by taking some wire and putting direct juice to the boost switch with the key on and didn't hear it spray. So i bought a brand new relay at the local napa and that fixed it for about 2 months and now again my meth won't work. I did my same little test today and all i hear when i ground the wire on the battery is a "click" from the actual relay. No pump action happens at all. So does anyone know what the problem may be? I've checked the inline fuse as well and it's fine. Thanks.
DP: Now when i put straight juice from the battery to the relay i hear the pump make a humm noise and no meth is sprayed. When meth sprays it ticks but now it just humms. I honestly have no idea whats going on and everything is wired fine, there are no rigged connections or anything.
alright man i'll try that, so just take some spare wire and push it down into the relay hole with the relay actually off?
If the relay clicks it's working properly. I'd say check your pump ground lead. I'm thinkin maybe your pump is going south.
14.330 @ 96.37mph
Well the relay clicks and i can't test the output because i only have a small test light with 2 wires and you need 3 for the output. When the relay clicks i hear again the pump going hmmmmmm but not ticking like it should. What does everyone think i should replace, pump, boost switch?
Have you revised the diameter of the cable? it is possible that it is too thin for the voltage. Up to now I have not had problems with my progressive collingmist kit I have configured it to 4 psi
