Hey all, I was just wondering what gap I should use for my application since I will be supercharging it I know its different than stock. So any of you M62 Ecotec guys speak up and let me know what you used....I may call wiseco but just wondering what some of you have used...
Wiseco 10:1 cr, 20 overbore
thanks for any info
PROUD MEMBER OF JBOK.
so no one knows what the gaps were for the rings? I know some of you actually built your own engine, or hope so.
anyone?
I need to bump this, does anyone have any info on this? Wiseco is closed for the night, and I need the specs?
any help is appreciated
I know Phlatcav has the same question a while back before he sold the silver cav. I remember reading the thread about it and keeping it mind for when start building.
Try doing a search. I know its here.
ok I confirmed it from another site
1st ring - .023" - .026"
2nd ring - .020" - .023"
thanks man
Is that for the 2.0L SC motor? If so, you're going to need to scale those nubers with bore size.
fortune cookie say: better a delay than a disaster
no this is for a 2.2 ecotec.....do you have any info for me?
if so thanks
I would open the gaps up a little for ANY boosted motor. Seeing as those are aftermarket forged pistons, I'd go with the manufacturer's recomendations.
i will call wiseco and see how they compare to those specs above.
Tha01cav wrote:ok I confirmed it from another site
thanks man
those are the specs I used.
