My car is smoking real bad out of the exhaust idk what it is anyone have any suggestions??? help asap
What color smoke?
5K PB: 24:50
10K PB: 54:26
Coolant for sure. Time to see if you can light your coolant with a lighter. If so your HG is toast.
5K PB: 24:50
10K PB: 54:26
I know what color of smoke is, but I bet this kid cant see the blue hint in it for oil
LE61T PTE6262 Powered
Could it be that it's a brand new turbo? Mine smoked for a day then stopped.
no its used what should i do 2 c if its coolant and if it is coolant should i flush it and put new coolant in it
also could it be my headgasket?
Dude, just smell the exhaust.
Sweet = Coolant.
Burning oil = Washer flu.. I mean Oil..
My Guess is that you have too much oil pressure going to the turbo, and your blowing past a seal. Is this a ball bearing turbo by any chance?
no its a turbonetics t3 60-1
also when i floor it it feels like i have no power like fuel cut so idk what it is why it would be doing that
quick question..
what are you doing to fuel this beast?
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
check your oil for coolant...........
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
i have 310cc injectors a obx fum and a afpr
Adam Lewis wrote:also could it be my headgasket?
pressure test your coolant tank but if your getting white smoke at ild you blew you head gasket
THERE CAN BE ONLY ONE, i have already died once and im still here so lets just leave it on the track
dude, what does your exhaust smell like?
Is it sweet? Fuelish? Or like burning oil?
Adam Lewis wrote:no its used what should i do 2 c if its coolant and if it is coolant should i flush it and put new coolant in it
Why, so you can burn new coolant instead of yucky old stuff?
14.330 @ 96.37mph
it smells sweet not like fuel or oil
Changing your coolant will not help. It is not burning your coolant because it is old it is burning it because it is leaking past the head gasket. You need to rplace the head gasket and when you do that have the head checked for cracks. Most likly it is just a bad head gasket. Do not continue to drive it as I bet it has contaminated your oil or will soon.
Lefix wrote:Get a Cometic Headgasket for turbo applications... should fix the problem
What about it exactly makes it for "turbo" applications?
fortune cookie say: better a delay than a disaster
Check your coolant overflow cap. It smoked white when I overfilled the coolant and I think the cap was kind of welded there so it didn't overflow......
