Hey I bought one off ebay about 6-8 months ago, to install with my setup. Just found out that it cracked...
I have been having some white smoke coming out of my exhaust, I hope this is the cause because this will be easy to replace... Does anyone know where I could get a cast iron or SS mani for a 2200 OHV engine?
btw... 1999 ohv, t3/t4 hybrid turbonetics, 8psi, fmic, hptuned.... internally wastegated
I'm not sure what we will be selling these for, but I should have more info in a week or so.. Here are a few pics of the one we are making for my car. It is just tacked to the flange currently. 304 Stainless Steele, all tig welded. This is also very similar to the one we made for "CAVCRAZY"/"Tommet" 's car...
P&P Tuning
420.5whp / 359.8wtq
White smoke generally means burning coolant and that more than usually means head gasket. However it can mean a couple other things too but hope its just the head gasket. Might wanna check your compression soon.
same place mine cracked , its because the turbo is so heavy and when it gets hot it makes that side sag. you have to make some kinda brace..... also i welded mine. and wrapped it in heat tape to slow cooling
You think you could make one with the flange and an outlet for my turbo in relatively the same spot it is now ? if so PM me and we'll see what we can do
also thanks for the replies guys
Derk Eliso wrote:You think you could make one with the flange and an outlet for my turbo in relatively the same spot it is now ? if so PM me and we'll see what we can do
Could be possible..... Would you be able to send us the old one so we could verify location??
P&P Tuning
420.5whp / 359.8wtq
