In regards to the GM Supercharger kit installed on my 2000 2.4L, I am trying to physically locate the Intake air temp sensor (IAT). On the S/C kit parts list I noticed the air duct plug (#88960479) and air temp sensor wire loom (#12051375). SInce I had a GM dealership install the kit, I am assuming the kit requires relocating the IAT sensor?
My question - where is the IAT now located (as per factory kit installation) since the air duct mount is plugged? Can someone please post a quick pic or discribe the new location? I found the MAP sensor, IAC valve, and TP sensor locations around the TB.
Bottom of the charger manifold. Lay under your car, like your doing a oil change...... you'll see it.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
ya the sensor is the one only 2 wire sensor you can see under the supercharger. there wont be a part number in the s/c book because you re-use the original one when you install the supercharger.
Driver's side of the manifold, down beside where the MAP hose connects to the charger.
14.330 @ 96.37mph
Thanks Brian and all,
That explains why I could not see it from the top.
To All,
Thanks again, the IAT sensor was beyond dead, but the new one is now running good.
