I can't answer all of your questions but I do know that the fuel pump is from a 4.3L V6 Blazer, I believe you can get it from an S10 with that same motor as well, don't quote me though.
It beats a Honda!
This one is 12:1 ratio and it's too much....
You should go with a adjustable ratio FMU like the BEGI 2025.
You will need bigger injectors to achieve a good AFR and to be safe.
I have 310cc injectors and they're too small even at 4 psi....
Good luck!
can i use smaller ratios ... bcause they are some with smaller ratios like 8:1 and 10:1
and which type of injectors shall i purchase some people have told me that ford brown head will work .. but im looking for different options. my car uses low impedance , do i need to use low impedance or can i use high impedance too ?
thanks
use low impedance & low impedance only. I don't have much experience w/the 2.4L TC but I do own a 2.3L Q4 & an Ecotec & I know that you need to stick w/low impedance injectors on a Cavi
It beats a Honda!
could some one please help me getting bigger injectors for my car ?? can i use other gm's injectors that are bigger ?
thanks
Would you like everyone to spoon feed you pablum, and wipe your ass after you take a dump too?
14.330 @ 96.37mph
get injectors form a Cobalt SS/SC if you wanna stick with GM/AC Delco stock type injectors. Make sure you get the injector clips as well. BTW BlownBlackZ is right part of building a car is doing the research & not having someone tell you what to do step by step. Try using the search botton it really will save you a lot of smartass post from coming your way because chances are the exact same thing you wanna do has been done 50,000 different ways.
It beats a Honda!
