Does anyone here have problems with their turbine side bolts not staying screwed on tight? Cause every few days I have to keep tightening them so my down pipe doesn't fall off while im driving. I already had one bolt fall off completely and I also have lock washers on it.
ig
Happens all the time. Any bolts going into the turn are extremely pron to back out. What style lock washers are you using and what kind of bolts?
______________________________
'96 GSX
towed more often than driven
Low Boost - 12.31 @ 115
- 349awhp/304ft.lbs
Try using some loctite on those thread.
Save your money. It might be worth something someday.
ahah damn wish i had that problem.. i used anti siez lub on mine and after 2000kms i had to pull them out and they were stuck so hard in that i broke one right off...
The First Twin Charged jbody
studs and nuts (double nuts to be exact). Little bastards didnt want to come out when I had to remove the head.
Couldn't you just use some split lockwashers, that should solve your problem.
I found that split lock washers become regular washers due to the heat they are exposed to.
Sorry, but I haven't been on for awhile, but thanks for some of the suggestions. I also have used split lock washers and they do become regular washers after the second day driving around.
Thanks
IG
