ok so long story short. the flex pipe has an exhaust leak in it. the location is right before the base of the firewall. i believe it might have rubbed on the firewall for sometime.
so my question is, would it be wise to move the new flex pipe right at the base of the firewall or is that too far?
i had to use a 1" spacer when i went with the 20g upgrade from hahn. (moved it futher back from lines due to heat) and due to that, it hits the firewall.
and what size is your dp?
http://www.myspace.com/15102113
12.5@116 2.0 60ft 19psi
Its no Hahn Kit or and Eco but i hope it helps you.. 2.5"DP all the way out....sry but its the best pic i have..
Its no Hahn Kit or an Eco but i hope it helps you.. 2.5"DP all the way out....sry but its the best pic i have..
PhilioZ24 wrote:Its no Hahn Kit or an Eco but i hope it helps you.. 2.5"DP all the way out....sry but its the best pic i have..
dude thats perfect. thank you.
btw how long have you been running it like that? have u had any problems?
Mine is just like Philio's too just 3", no problems at all. I had the same thing happening with my DP when I got my 20G from Hahn, till I upgraded the exhaust too
wasp96 wrote:Mine is just like Philio's too just 3", no problems at all. I had the same thing happening with my DP when I got my 20G from Hahn, till I upgraded the exhaust too
hows the clearence with the 3" dont mean to be a pain but can you post pics of it down by the turbo manifold or underneath?
due to the location of the flex pipe im going to have to get a new downpipe reguardless. gives me an excuess to go 3" just like to see what my friends shop is up against
I have had no issues with it so far.....no knocking or anything against the firewall.....
I will try and get some shots of it this weekend, we are doing some work on the car so I can get it on the lift and get some good pics.
wasp96 wrote:I will try and get some shots of it this weekend, we are doing some work on the car so I can get it on the lift and get some good pics.
thanks man. greatly appreciated
Hey PhilioZ24, How much do you like that magnaflow resonator? I am thinking about purchasing one, but wanted to hear some opinions.
Timothy Pietraallo wrote:Hey PhilioZ24, How much do you like that magnaflow resonator? I am thinking about purchasing one, but wanted to hear some opinions.
actually that is a 2.5 in/out magnaflow muffler....it sounds really good......it doesnt have that raspiness on cold startups either..
John H [CavalierKid wrote:]how much was it to get your down pipes made?
i made the downpipe. well, i mocked up the pipes and how they lay and had a friend tig them together ....i ordered some tight radius 90 degree bends and flanges
Sorry John, couldn't get the car on the lift this past weekend. It looks just like Philio's though, just 3". I did the same thing as him as far as what I ordered too. The guys said there was plenty of room for the 3" bends I bought. If your guys are experienced welders it should be no problem. I did use the O2 housing that hahn sent with the kit because it was going to be tuff trying to get around the air conditioner piping by the firewall with that 20g spaced out. Let me know if I can be anymore help. I will get some shots, I just don't know how soon I can get them.
