Ok here is my problem. i've been searchingthe forums and i've found nothing but z24s and 2.2 ecotechs turbo conversion but none for the ohv and thats what i have. i got a built up motor and i want a new manifold thats does top feed injectors or something that can convert the fuel injection i have now into top feed.
Is there any engines with the 2.2 sohv turbo'ed that could swap alot of stuff off. sorry but i don't know what things can be swaped onto others.
1996 Chevrolet Cavalier "Its Far Away From a Stock Cavalier"
there are tons of boosted 2.2 and 2200 motors on the org. Im sure you will find something. What I have seen of the older 2.2L with top feed is having injector ports machined into your intake, and you use a fuel rail from a 2200 motor to do the conversion. If you do some searching you should find some pics. check the classifieds I see top feed manifolds on there every so often. If you need a 2200 fuel rail, PM me, I have some for sale....cheap too.
