Just got a real tial wastegate from atp....now is there a way to shift the bottom boost connection so its on the side and not on the back....cause right now it hits my cam tower on my 2.4 and i cant tighten it down...any ideas
you scratch my ride IMA EAT YO CHILDREN
i do believe you can take it apart and turn the bottom half of the wastegate
Really? that would be amazing, because mine is hitting there as well.
if i remember correctly, once you take out the six hex bolts on the top half take the spring out, then there should be a set screw that holds the vavle to the diaphram.. loosen that, remove diaphram.. and then there is a big nut under there that holds the bottom end on, loosen that and turn.. put it all back together..
its been awhile since i have taken one apart.. but i happen to have one sitting in front of me right now. i'll see if i have the tools at home to take it apart tomorrow.
I had to take mine apart and clock it back in the day........ been using it for 4 years sence w/o any problems.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
take it apart and its one bolt....i got it.......the 6 hexs...the 4 tiny ones that hold in the plunger....then one big bolt....loosen it and itll spin freely.....i moved mine to the front where the other exhaust port is
Okay, I've got it all apart, the set screws out, the plunger out, and I can't get it still. How do you under the diaphragm? Just yank it off? I'm hesitant to do it because I'm not sure if I'm supposed to?
i pulled those 4 screws off completly.....the plunger is kinda wedged in there....when u flip it over the top peice should just fall off
Hmmm I took them all out and still nothin, yanked a few times, shook it a bit and nothing fell out???
Any suggestions? Thanks man!
try maybe twisting the metal top peice.....myne was brand new and just kinda fell apart......but yea with myne the orange peice came off with that top peice....but try twisting it back and forth and see what that does
Awesome, success! Just took a bit of convincing. It's perfect now, thanks for your help!
not a problem man...glad u got it....what kinda spring u got in it?...i put a 5 psi spring in mine.....the guy said it would be good to like 13 or 14psi with a boost controller....
16 Valves Of Power wrote:not a problem man...glad u got it....what kinda spring u got in it?...i put a 5 psi spring in mine.....the guy said it would be good to like 13 or 14psi with a boost controller....
Depends on the controler..... some manual ones can only go 2x spring pressure...... our drag car setup maxes out at 11/12psi (6psi spring).... we have a TurboXs manual controler.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
