Ok, I was wondering if anyone else has had an issue with belt clearance, last year at the track my belt rubbed a hole in my coolant hose after the zip ties broke from launching, now I went outside got in the car and went to turn the AC on and nothing happend. The compressor didnt even turn on, so I bought a recharge kit and started to refill the system and noticed there is now a hole it my AC line from the belt rubbing it. Has anyone else had an issue with the belt? if yes, what did you do to fix it? Thanks, Josh
lol i noticed this problem when i installed mine. i put a couple of zipties on the coolant hose and i literally tried my hardest to bend the ac line out of the way. i even put a bolt inbetween the compressor housing and the ac line to move it away from the belt. its been workin fine for the last month or so since i installed it.
http://www.myspace.com/xtremegravity
http://cardomain.com/ride/833995
i did the same thing
later,james
You can unscrew the AC line from the motor mount and move it easier that way... sometimes I wonder about you S/C guys
I used about 5 different color zipties on mine!!!! lol im ghetto.
i moved everything around when i was installing the s/c
over a year and no issues
