For those of you with a 2.2 ohv, turbo'd... how did you route your exhaust piping? I have a hybrid t3/t4 turbonetics turbo with the ebay manifold. Thanks in advance...
Ummm...the same as stock...
fortune cookie say:
nevermind, i know how to route it, I meant for the downpipe, and the bend from the turbo ... nevermind I have to have an exhaust shop do my exhaust cuz they need to do bends and stuff... and I can't order an exhaust to just to hook right on....
with everybody's setup being slightly different, its almost impossible to get a generic exhaust system made up.
(Unless you bought an entire turbo kit)
You have to custom fab a down pipe... I'm having a local mechanic do it for me.
If life starts to pass you by, Downshift!
cav22boost's Avatar
THE WAY I SET MINE UP WAS TO GO OVER THE WATER NECK, UNDER THE ALTERNATOR, THEN DROP DOWN WHERE THE AC USED TO BE. THE TURN DOWN OFF THE TURBO WAS TOO TIGHT AND WOULD HAVE RUN INTO MY WATER NECK IF I FOLLOWED THE STOCK ROUTING.
you do realize that this thread is from April of last year right?
