Hello all what are you guys using for radiators on high hp boosted Z24s, is the stock radiator with a second fan or dual fans sufficient or is a bigger all aluminum one needed, especially since I'm keeping my a/c?
2000 Z24 5spd header & catback for now.
i think they offer two radiators for the cavys. one slightly bigger and one smaller. two fans would be nice to. also run a switch in the cab so you can turn them on whenever or wire it to the ingition.
only thing i did which made a huge improvement.. was have the fans come on sooner using a HP tuner... my car ran cooler with the turbo and s/ c'er then it did when i bought the car
The First Twin Charged jbody
my car could not keep its cool with the v6, headers, and turbo. even with the fans coming on much sooner.
can anyone reccomend a known performance rad?
farmerz24
make a fluidyne work. stock will be fine though, at least on a 2.4
Thanks guys as for my hp/tq goals hopefully 500hp/480tq at the flywheel so the stock setup with dual fans and modified timing with HPT should work. What about the thermostat, are you guys using the stocker or would a 160* be better?
