Hey guys, ive searched and searched, and couldnt find a pic of exactly where I would hook up a boost gauge. I am going to be supercharging it, and figured id start the early preparation. Maybe someone could circle or show me where the nylon tube should go for the hookup.
I'll take pics of mine and post, I have a Auto Meter and GM M45 S/C set up.
"T" off the the vacuum hose coming off the fuel pressure regulator.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Skilz10179 wrote:"T" off the the vacuum hose coming off the fuel pressure regulator.
By the way I really like your car skilz.
Ok here is mine
starting at the fuel regulator
along the wire run
Behind the brake master cyl
Behind the air box and through the firewall
Into the interior to the sensor
Wires to the gauge pod
Hope it helps.
Holy christ that's a lot of steel hoses...
14.330 @ 96.37mph
od1z24 , please fix that map sensor for the boost gauge , the line has to point straight down
even tells you to mount it that way in the instructions
Thanks for the heads up! Lost a tie, tie. Done.
[quote=97trd(???™)]od1z24 , please fix that map sensor for the boost gauge , the line has to point straight down
While he mentioned it, maybe this will help you.
http://www.autometer.com/download_instruction/569.pdf
that helps 100%! Thanks a bunch for the pics and info!
Well, I looked under the hood, and my engine looks setup differenty (ecotec). On the side of my fuel rail, I dont have the piece where you t'd off on the line. Anyone else?
sscavalier wrote:Well, I looked under the hood, and my engine looks setup differenty (ecotec). On the side of my fuel rail, I dont have the piece where you t'd off on the line. Anyone else?
No you do, it's your fuel pressure regulator. Look on the right hand side of the fuel rail. You need to ADD the "T" though, it's not already there.
J-Body Club of Ontario (JCO)
Yea, I think I got it. I have the barbed t. Is it the tube that comes from just beneath the throttle body, looks like its on the intake mani? Maybe you could post a pic of an eco motor and circle where I need to do this. I just dont wanna f something up for no reason. Thanks for all the help.
