Ok so I'm working on a project on my 1.8 and thought maybe you guys could help me out with something. I currently have an internally gated T3 super60. If I remove the wastegate and the actuator and the swingarm housing I'm left with what appears to be a normal externally gated turbo, except i now have a second hole in addition to the exhaust outlet on the hotside of the turbo. Now my question is to run this externally gated, do I need to run a special blockoff plate to seal that small hole? Or if I run a standard 5 bolt flange on there will I be fine?
Standard 5 bolt flange will work fine. Let me check out the turbo before you order anything though.
Cardomain|
Myspace
Oh Josh and good news I have something on the way
, its got 4 long tubes of equal length and it's made of stainless, any guesses?
yah, you can buy anything with a 5 bolt and it will block that off....
but have someone with experience check out that turbo before you buy, 90% of the "super 60's" are not really super 60..
ge_forcez22 wrote:yah, you can buy anything with a 5 bolt and it will block that off....
An easy way to check if your getting a real super 60 is to meausure the compressor wheel size. I belive majesticturbo.com has the specs on wheel sizes.
can you just remove the vac source so it doesnt open?
I mean it would look gay and all, but this is for my own personal knowldge
Kick azz is my boost hero!!!
yah, inducer / exducer = trim..
you want trim = 60
so if inducer =30
exducer =50
then trim =60....
your numbers will be different but should equal 60
