Ok guys, I found this and want to know if anyone knows anything about it or have tried it. If I have to I can be the guinea pig, but of course I would rather not.
null
looks like your standard standalone, but for 1900, you could do better.
YUMMY!
wow! thats the shi7! if that works good then it would be a great buy!!!!! that freaking wiring harness is disgustingly beautiful!!!!!
if this controls everything that a regular standalone does... like timing, fuel, boost control/trims, and all the other nice stuff that AEM and many others have AND its plug and play.... then this is a huge find for us....
i think 1900 would be a good price if this is what im thinking it is
98redcavz24 (LD9Stunner) wrote:looks like your standard standalone, but for 1900, you could do better.
name ONE other standard standalone that works for our cars? plug and play like this one? im genuinely interested.
wow sounds great but yeah the price is steep
making your own wiring harness is so much more rewarding though
I posted a link to this about 2 weeks ago. It never showed up though.
You're paying $1900 for an ecu and the tuning software. It's a GM ecu, the MEFI, designed for Marine use, and it uses all GM sensors. It's a damn good piece of equipment. Stories I've heard are that these controllers are used during R&D on original engines and sometimes when GM is building a concept car. Same ecu is used with some Harley Davidsons and with the Ramjet V8 engines. I used a MEFI2 on a 67 Chevelle for a while.
If ya wanna save some money, the software alone should be about $600 - $700.
http://www.azspeed.com/inmaso.html
You can get a MEFI 4 controller for about $450 from gmpartsdirect using part no. 88962717. The old MEFI3 part no., 12489488, doesn't come up as a good number anymore. But they show up on Ebay from time to time.
Then you need to work out details for wiring harness, ignition, etc.
hth
-->Slow
slowolej wrote:Then you need to work out details for wiring harness, ignition, etc.
can you please be 1000 times more specific
ignition? why doesnt "wiring harness" encapsulate ignition?
Edited 1 time(s). Last edited Sunday, January 21, 2007 11:09 PM
Because the wiring harness is the wiring harness, and the ignition system is the ignition system.
Kinda like "why doesn't tires encapsulate wheels?" Different parts, bought separately, to work together.
I don't have an Ecotec and I'm not involved in installing one of these ecus right now, so I have no specific information to hand out for this swap. I could probably research specific questions. If you choose to save money going DIY instead of buying the whole package then you'll probably have to do some of it yourself.
-->Slow
slowolej wrote:Quote:
-->Slow
true! thanks for the answer!
anything you find, im sure would help a lot of ecotec owners. . . . . i will start looking into this as well...
BTW that harness has an icm connector....
LE61T PTE6262 Powered
