Ok im ordering rods, pistons, gasket, arp studs soon.... But i see the diff sizes in Cometic gaskets, since im boring my block .020 which gasket would fit me best?? I tried searching but to no prevail.
Im puttin in the weisco 8.9:1 pistons and i dont see a need to drop compression any lower so which gasket should i go with?
<img src="http://memimage.cardomain.net/member_images/3/web/831000-831999/831395_11_full.jpg">
.043" is stock, so go with .040" Cometic
-Aaron
www.TurboTechRacing.com
Aaron, not to steal sales from you but ben take ym advice and use the stock MLS gasket, Suncavi and myself are both using them and him at 25 psi. He and several other people had problems with cometic gaskets leaking in between the cylinders...
LE61T PTE6262 Powered
I will personally say do not use the 0.030 thickness one. I just ordered a 0.074 from a local shop, I will post results on that in about 2 weeks.
those wiseco dish pistons are the perfect way to lower your compression, using a head gasket to do it is not a great idea, so by using something as close to stock you should be just fine.
QBE - those gasket that are leaking did the guys use any copper seal or did they just put them on dry?
For the bore just get the 87mm one. It'll be fine even with a .020 overbore.
5K PB: 24:50
10K PB: 54:26
so even with the +20 thou the stock one is large enough?? I did a quick calculation and I think the gasket is still larger than the bore, so it should be all good.
Even with a .030 overbore the stock gasket bore is plenty big enough.
5K PB: 24:50
10K PB: 54:26
thanks hypsy, I wanted to hear that exact answer, you are the man
ge_forcez22 wrote:thanks hypsy, I wanted to hear that exact answer, you are the man
Not a problem. You know how to get a hold of me if you need anything else.
5K PB: 24:50
10K PB: 54:26
Fel ro stock replacement FTW.
My Cav
I give up...
Fel Pro*
My Cav
I give up...
Who all has had issues with the cometic?!
cometic are MLS gaskets... there should be no way to blow them out... this is the first I have heard of it. If they blow out I wonder if something was installed incorrectly.. because the gasket itself will not be destoryed.
I've never had a problem with mine....although everyone KNOWS SOMEONE who has but has never had it happen themselves. Sounds like a bunch of he said/she said going on.
5K PB: 24:50
10K PB: 54:26
Phlatcav wrote:Who all has had issues with the cometic?!
I have one on my civic ... and i over boosted a few times to 25-30ish range ... and not a problem ..
..... ^^^^ The only Hondas i like, nice car
ge_forcez22 wrote:cometic are MLS gaskets... there should be no way to blow them out... this is the first I have heard of it. If they blow out I wonder if something was installed incorrectly.. because the gasket itself will not be destoryed.
the stock L61 is a 2 layer mls.. lsj is a 3 layer MLS I am going with an lsj head gasket when my head comes off for the aptriot
