Yes, it is a direct bolt on for the 2.4L. I actually had that same one for a while until it started to go whacky, and had to send it back to Summit.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Yes it will work on your car. Alot of us are using them, although some have had problems as did Luke.
Yes it will work, I have that one.
I believe the ECO's use the
74566
1 fits the eco , the other the 2.4
ive got 1 in mine , works great
well sweet F%$k man, looks like you are in luck, you will get that base pressure down, get your fuel milage back, and then you can hit the dyno and get a good tune, cheers
I actually have the one for the ecotec, 74566? Does anyone know if it would work on the 2.4 because it didnt work on my bro's car (eco); started leaking.
you should get the one meant for your car, although im sure you can get the other to work...
Nope, the 74566 won't work...Bolt hole is on the opposite side of the LD9 fuel rail...you would have to fabricate a new mounting bracket for the FPR...sorry bro.
Did you use any kind of lubricant, such as petroleum jelly (vasaline), to ease the o-ring into your brother's Ecotec fuel rail? I did that for my LD9 and it hasn't leaked yet. Maybe you damaged or have a damaged o-ring. Make sure you bolt it up too, if you may have possibly forgotten before.
