fuel regulator and FMU - Boost Forum
Monday, January 01, 2007 9:11 PM
Is there a difference between a fuel regulator and an FMU. I'm trying to piece together a 6 psi system to help me get around town just a little quicker. Also are waste gates adjustable for the psi they open for or do you buy a waste gate specifically for the psi you want. As far as charge pipes go, will an inter cooler kit off eBay include all the pipes I need to make a custom setup. Thanks.
Re: fuel regulator and FMU
Tuesday, January 02, 2007 4:45 AM
The "What is a fuel system" FAQ sticky at the top of the page
The "Parts List for a custom turbo kit" FAQ sticky at the top of the page
The "New Boost FAQ" Sticky at the top of the page (the one that says READ BEFORE POSTING
And no, most wastegates that come on turbos are not adustable. The threaded rod, contrary to what people think, is not meant to regulate boost.
Tuesday, January 02, 2007 6:08 AM
no, a ebay intercooler piping kit will not include everything you need. you will need custom work for your intercooler piping, and for your exhuast work.
a afpr (adjustable fuel pressure regulator) allows you to regulate the fuel pressure, this is to help tame bigger injectors at idle, some afpr's even have a 1:1 reference which means that per psi of boost it raises the fuel pressure forcing more fuel through the injectors. aeromotive makes nice ones. not all afpr's have a 1:1 reference.
a fmu add's fuel per psi just like the afpr's that have a 1:1 reference, but it can only raise fuel pressure, it can not lower it. it can also raise it by a lot more then 1:1, they have some that can do 12:1 which increase your fuel pressure by 12 per 1 psi of boost... this is why people ruin their stock fuel pumps and get a walbro 255l or 190l. they make sfmu which allows you to adjust the amount of fuel pressure changed per psi built up. i.e. 1:1 - 12:1
external tial wastegates (what i have) allow you to switch out springs to change the psi you want to run, also, you can run a boost controller on the vacuum line running to the wastegate and change it to be higher... u can only go as low boost as the spring in the wastegate. i dont kno about internal wastegates, but ima assume that shifted is right cause he is smart so listen to him if you are getting an internal one.
